RE: E-flite Habu 32 DF ARF
I installed the optional main landing gear doors using the procedure described in the manual. The supplied gear door blocks are sanded on one side to curve the doors around the main wire struts and on the other side to help center the gear while it is retracting.
I painted the gear door blocks grey to cover the wood color and help them blend into the model scheme.
