Originally posted by HarryC
It won't even see one. When the PCM Rx gets one bad frame, then it does as you said, and passes the last good data to the servo instead. So the servo only ever sees good data, and it has nothing to tell it if that data came direct from the Tx or if it is hold or failsafe setting data from the Rx memory. All it ever gets is a valid ppm time signal. So I would like to know how a glitch counter works on a PCM output.
H
It appears to me that you are correct. I sure would like to hear from someone that has tried it on a PCM receiver.
If not, when I return to AZ in Oct I will try it. I have access to a glitch counter there
