RE: MAVERICK BLACKOUT: Do i need a new clutch bell?
I don't think you need a new clutch bell. When go to start the engine the gears shouldn't turn, the fact that they are turning means your clutch is engaging the clutch bell which leads me to believe you either have a bad clutch or clutch spring. I would take out the engine a inspect your clutch. You might also want to post your issue in the Large Scale section and also check out Redcat Rampge Forum, your Maverick is the same platform as the Rampage and they have a ton of info over there that will help you out.
I also noticed your gear plate is missing the top two bolts that attach it to the engine or did you take those off to work on the truck?
