ORIGINAL: Tony Hallo
I used hair spray on my last build, sprayed the wings and fuselage after 220 grit and before 400 grit sanding. Will continue on future builds. I was using Monokote. Try it you'll like it.
Do I understand you right, you used hair spray than sand and then use your monokote, it that right?
wattmeter
