SD-10G & RX700 Range Check
I just purchased an Airtronics SD-10G with the seven channel RX700 receiver. After installation and configurationin my 2M pattern model the radio only range checks out to exactly 50 feet (used a measured string) on low power modebefore loss of response. The model was elevated three feet off the ground with no obstructions for the check. The transmitter antenna was oriented vertically. Obviously, I am extremely concerned as the instruction manual recommends 90 feet. I realize there was an issue with the FHSS-1 receivers range checking low, but this is a reduction of 45%! I have both antenna wires oriented at 90 degrees in plastic tubes precisely as instructed in the manual. The coaxial cables are not kinked or otherwisebent acutely. These tubes are away from servos, batteries, and wiring. What can I do to attempt to remedy the issue?
P.S. Some additional tests at varying angles had an observed range as low as 27 feet before glitching occured!
