RE: You Can Do Engine Problems
Very common problem with inverted mounts if the fuel drips and syphons there is only one solution Lower the Tank as already has been noted. The same relative tank center/carb jet relationship must be maintained with an upright or an inverted mount or there will be runing problems.
John
