RCU Forums - View Single Post - reversing servos
Old 08-19-2003, 06:54 PM
dant-RCU
dant-RCU's Avatar
Default reversing servos
If you have access to or can find someone who has the Hitec digital programmer you can reverse one of the servos.
It is my understanding that doing this and using a standard "y" harness works just fine but that digitals do not like the "Smart-Y" reversing harness. I am getting ready to do the same thing with two elevator servos.
If you lived here you could use my programmer........
If you set the servos to point in the same direction (thereby having the same direction of rotation) then you should make sure that the servo-end connection (servo arm) is the same distance from the fuse centerline as this should keep the pushrod geometry the same for each half. I did this successfully in my GP Spacewalker and it has worked fine for 4 years.
Just my nickle here....
Dan
