ORIGINAL: steveelkin
Yes this came out of a volcano sv and it is most definitely the spur gear setup. I doubt that the gears are supposed to be swapped around as this is a stock picture from redcats website. There was not an eclip but that might explain what is going on if it is the case that there should be one anyway. And yes I took it apart to replace the spur gear. I even watched the how to video. All I know is that this thing is about to get jb welded together if I don't figure something out lol
if an "E" clip is supposed to be there, then the shaft will have a slight indent or slit for the "E" clip to go onto. if there isnt one, then no "E" clip is to be used.
can u take a photo of your actual part? a couple differnt angles maybe? it might help us help you.
