RE: Stihl 4-mix 65cc questions
Did you use a spring with the fuel pump diaphram on that setup? Have any videos of it running?
I used a return spring in the fuel pump of my Honda four stroke, but I think the design of the Stihl, being more like a two stroke in actual operation might not need a spring. However, the stock carb has a special spring and diaphram setup for the fuel pump.
AV8TOR
