RCU Forums - View Single Post - Fuel tube size for 95AX and 1.20AX
Old 09-12-2011, 12:12 PM
rg1911
Default Fuel tube size for 95AX and 1.20AX
What is the correct fuel tube size for these engines? There are no recommendations on the O.S. or the Tower sites.
The 1.20AX hasn't been installed yet. The 95AX went from being touchy but working to not working. The club's engine guru has spent several hours trying to get it to run reliably. If, and that's a big if, the plane gets off the ground, the engine quits after a few minutes. Usually, everything gets adjusted, and as the throttle is advanced for take-off, the engine dies. All of your previous suggestions have been done, to no avail. The only thing I haven't changed is the size of the fuel tubing. Since life is too short to fuss with a temperamental engine, I'll be looking for something different.
I just hope the 1.20AX works better.
Thank you,
Richard
