Fenderbean:
Your Rhino may or may not need to go through the "throttle learning." The ECU software version will let me know if this is necessary. Software version can be found by menu up to the second screen which shows battery V, pulse and % of throttle trim and stick as well as V of software.
Software versions change often resulting in possible errors in the manual.
For training purposes, simply start, let sit at idle, the go to full throttle. Wait at full throttle until rpm reaches max and PW stabilizes. THEN and only then, reduce throttle one click at a time pausing 5-10 seconds at each interval until arriving at idle. You have now completed the learning process.
For quicker response to your questions, please email me @
[email protected] I only check RCU 3 times a week.
Best regards,
Eric
