RE: AN HONEST QUESTION 4-U !
Mr. MODERATOR
thanks for the answer. I have many helicopters w/flybars all. Only one FBL. The mCP X
the reason I want to continue into FBL is hard to explain since it is mostly an INTANGIBLE FEELING
for a much more STEADY, SECURE, STABLE, RESPONSIVE KIND OF FLYING that only the mCPX has
given me so far. I feel I want to continue experiencing this in my next helicopter which would be
this MiniTitan scaler.
A similar situation showed up for me in the early 60 s when for the first time I switched from highwing
dihedralled clunkers to a PATTERN AIRPLANE.
After switching then (for the feeling) I never looked back.......same thing is happening again.
RICK
did I make sense just now ?
IF YOU SHOULD READ THIS POST AGAIN : Would you mention the BEST COMPONENTS I should get to do this UpGrade to FBL ?
I registered you advise for the BEAST X and at $ 199.00 it sounds reasonable if, as you say, it's a good one.
Then what about the head ? which brand, model do you suggest ? I think I will stick with a conventional 2 blader, don't want
to get too complicated with multiples......
thank you RICK
< Message edited by Barrrick 9/20/2011 1:50 AM >
