Programming a 3Way Switch on SD-10G
Hey guys and I want to thank you in advance for your support and the great forum, I have lurked here for a long time, but I got my butt kicked by this and I need help.
I have my SD-10G, and I have used it for mostly Helo's. But then I got into multi rotors. Well this one I have doesnt want you to be in Helo mode. It wants Airplane mode.
Well I was using the Gyro gain switch for the Mode switch on this Fyetech FY 91Q system. It worked perfect, I have a gyro range of 150 to -150. I just set it up for
the different values and I got all three modes the FY-91 Q has. Regular flight, Return to Home, an Altitude hold. But then I saw NO helo mode. So I switched
to Airplane mode and the WHOLE GYRO function goes away.
Now I want a simple 3way switch that puts out a range of values and I cant find out to do it, AND I READ THE MANUAL!!!!
Anyway, does anyone have a quick way of doing this without having to use BOOLEAN Math? I want the same switch to do that mode changing.
Thanks guys
Paul G>
