ORIGINAL: tim wan
ORIGINAL: Greg Covey
Hi Tim,
When you order the T-33 model, does it comes with both mounting options for either a 90mm or 120mm fan unit?
Can you post more information on your testing the T-33 with the 120mm fan unit?
Regards.
Dear Greg,
If the order mentioned come with both of 90 & 120mm fan related bay units that we can put it together (just add a litle bit cost).
Pls search RCLander T-33 / P-80 flying video where is some 120mm size testing video.
BRs,
Tim
Just to clarify Tim's comment here as often the meaning gets lost in translation. When ordering from your dealer you should specify that you need the 90mm or 120mm mounting blocks. The jet does not ship with both mounting sets. Although he mentions a small additional cost for the 120mm blocks, we really haven't noticed a factory upcharge for this option.
Here is a video of the RCLander T-33 flying with the 120mm EDF unit
[link=http://youtu.be/X4nSas6Pd3o]RCLander T-33 Flying with 120mm EDF[/link]
Regards
Max
www.parkrcmodels.com
