RE: RClander T33 for 90 or 120mm edf
Max,
Thanks for the information and video links.
Initially, I didn't see the DF mount options on your site because there is a display issue on that page using FireFox. I switched to IE8 and the page displayed fine with all the options.
This is indeed a product with many options! My plan is to use a Lander 120mm DF on 12s in the Thunderbird scheme T-33.
When you order the 120mm mounting blocks, is there a change to the thrust tube size? I don't see the 90mm thrust tube in the manual parts section until it shows up on step 36 of page 17. Perhaps it comes as a flat sheet of Mylar.
Regards.
