RE: 1/2A glow Mustang to electric convertion help
hello!!! I have a p-47 thunderbolt I'm trying to convert to electric as well. I plan using a 480 1020kv with a 30 amp esc. The box says 20-28oz plane but the equipment I'm using might knock that down a bit. I've noticed the firewall has a slight downward pitch in it so I'm thinking maybe I'll stick a washer in each of the left side motor mount screws to get a small amount of right thrust. As far as the rest of the plane, I have pretty much stayed with the plan that came with it.. If you have any advice I'd like to hear it! I think the plane you are converting is the same kit series as my p-47.. It has a 36" wingspan and calls for .059-.10 2-stroke motor. Kit number for p47 is K-12 so your mustang is probably a K-?. I'll let you know what I discover as I continue the build!
