Being new to gas and coming from glow airplanes, everyone specifies to use a nyrod throttle linkage to connect the throttle to the servo. You know, something like this
http://www3.towerhobbies.com/cgi-bin...&I=LXFU90&P=ML
But I am personally yet to undertsand how this works. I mean, if is there a nylon rod instead of the regular throttle push rod and do the metal push rods screw in both sides? If so, how flexible does it need to be? The throttle linkage on my Phoenix Extra 330s with Dle20 is fairly straight with little or no bend. Can someone explain this system?
Ameyam
