Originally posted by Pilatus
Does anyone know if the leads described at http://users.belgacom.net/TX2TX/tx2t...h/tx2txgb7.htm
actually work? The MPX - Futaba lead are plain pin to pin leads even though Futaba is on 9.6volts and MPX is on 7.2 volts. To make it work the Evo has to change output voltage, framelength, and neutral sync! Is that what the "UNI" setting is doing?
I'm interested in connecting my Evo to Realflight and the available interface is Futaba.
I made Oliviers set up and it works fine. Look on the e-zone radio discussion group for more info!
You must use the cable that does not supply power ! When you hook up, both sets must have batteries (and be swithced on obviously) and the pupil set must have the crystal removed!!
