Hobby Hangar 52" OV-10 Bronco W/electric motors
Seth here is some pic's I took of my electric conversion of my OV-10 Bronco.
Pic 1 is the side view to see the up pitch in in the Bronco.
Pic 2 is the up pitch in the elevator.
Pic 3 I add a hitec 125mg aileron servo instead of using the nyrods. I did this because I could not get the nyrods from binding up. I ran servo wire threw the nyrod tube to the elevator servo.
Pic4,5,6 is the battery setup.
Pic7,8 the ESC mounted into the nacelle.
Pic 9 this is not my wing but if another guy that did the same setup as I did.
Pic 10 I used 3' wheels on the mains and 2.5" on the nose. To me they look closer to scale but I'm thinking of changing the mains to 2.75" and the nose to 2.25". to see how that looks.
Pic11 is the lighter pilots I'm going to use when I install the retracts.
Pic 12 the Ov-10 Bronco up close.
Hope this helps let me know if you need something else.
Doug
