Futaba reveiver voltage question...
jchuston, the receiver can deal with as much voltage as the internal regulator allows. It automatically adjusts any voltage up to a certain value down to one that will not harm the receiver. If the guy from Futaba said 10 volts you can bank on it. However he's right, 10 volts will cause your servo's to glow in the dark => The receiver only adjusts the voltage for it's own use, not to the power bus where the servo's plug in.
