PowerBox and Pulse Amplifiers
I think it is time for a little redesign of the current systems by the manufactures regarding the quality and strength of the PWM signal coming out of the Rx's also I would love to see the Rx power buss that could handle at least 10 amps and then use an external power buss for applications that might see higher current levels.
one of the first things that needs to be changed if the connectors. I have a homemade power buss capable of only 0.02V drop across the buss at 20 amps and i am replacing the connectors with deans 3 pin on all the servos and leads. and going to 13AWG wire on the batt.'s with gold pin connectors capable of 20amp with little loss and heavy switches.
