RE: TT 40Pro endplay?
It is a trick and it might work but it is not the right answer. If the tolerance buildup between the crankshaft and the crankcase is such that the inner race of the front bearings end play is used up and the inner race is pulled tight against the balls by the Colet then the only good safe answer is a shim between the crank shaft and the inner race of the bearing even if you have to make one.
Denis
