RE: Hurrikane Build Thread
RE: SEEKER/HurriKane and SNAKER/Venom
Yes Gary and I had previously discussed this. And Yes there was a slight change when I converted the tail from the HurriKane to the Venom due the changed shape of the fuselage at the rear. (I knew this but accepted it as I didn't think it would make a big difference, as I would never set a tail without checking it's incidence relative to the wing.) I am not 100% sure what that dimension change is, but I don't remember it to be as large as 1/8". The drawings and cut files were updated. New Kits should be accurate. The Snaker was drawn after, this change was noted. Therefore, from what I remember I incorporated this into Snaker.
Out of all the models I have built, any of the 4, I never had an incidence problem. Please check your incidence when securing the tail.
DK
