RE: How to Setup A123 Pack with Charge & Arming Switch Capabilities?
Thanks for the tip ramboman!
While perusing the internet, I noticed that 4A is the maximum they recommend charging at using the balance connector alone. So using both connectors (or just the discharge connector for those that don't feel the need to balance every flight) seems like the only way to go for charging at higher C rates, and does coincide with what you are saying.
Mark
