needs some advice on my rhino
I think I just need ti increase the pump voltage or maybe the internal igniter up.
During auto start with kero I normally get about 2-3 ignition fails before it goes into preheat mode, then on 1st preheat the temp does not rise. So I abort and on the next start if cranks fine. So either its not getting enough fuel or ignitor isn't lighting the fuel fast enough. Or could it be both? Anyway after its running no problems, but have had the
The last 2 ground taxis afterlanding the turbine flames out, with no fault codes. So is it just a simple pump voltage increase?
