RE: The Evader Coalition ~ T.E.C. Part 2.
Hey guys, I came across a 15 bucks i can spend, i read somewhere but cant find it now that the Nitro Evader 60T 32 pitch spur will work on the evader ext2, i remember reading it is a tight fit but it will fit,,, so i have the nitro evader 60T spur awaiting on ebay however not sure what pinionsize i should go with,,,,, My EXT2 right now has the traxxas velineon system on it and im running a 90T (or maybe its 91T) spur with a 20T pinion and its just about perfect no high temps good overall power and so far no stripped diff so i want to keep the gearing ratio close to how it is but i forsure want to go up to the larger toothed 32P gears. Im horrible with math and or ratios so some help here would be mucho appreciated!!
