RE: 1/3 BUSA Super Cub Build
I am building the left wing panel first. Instructions do not tell you this but as I was taping down the plans for the right panel I noticed that the plans said " all detail on left Panel applies to right side "
Disclaimer- i will try to write this thread for those that have never built a Balsa USA Kit. BUSA doesnt always tell you step by step what to do i.e. " Build Left Wing First " and thier instructions are at times vague. These kits in my opinion are not beginner kits. At times a task will have no instruction at all, leaving it up to the builder. I learned this building the BUSA Triplane.
Also, BUSA does not over build anything, but they welcome you to modify to your hearts content.
At times I may explain somthing that seems pretty simple, that usually means I screwed somthing up and had to fix it.
