RE: Eagle Aviation One Design Build
The remainder of the rib blanks are installed. I like to install foam on the leading and trailing edges for gluing the sheeting. I cut the ribs with hot wire and attach the edges with 3M 77 contact cement. You can see the Formica templates held in place with clamps that guides the wire .
