RE: RC Aerodyne 500 size Apache
And, a couple more. I've still got camber, but no excessive toe in now. The only way to get the camber out would require plugging the tapped hole for the axle & re-drilling & tapping the hole at an angle. I'm thinking about it, but nut sure if it would be worth the trouble. I got the mtr mounted in the frame & started installing the servos. I had to do a little grinding on the frame to get the servos to fit. Then, I found that I need to make spacers for two front servos so that they don't bottom out on each other.
