RE: Magnum XLS vs Thunder Tiger .15
Do you know which pipe you're using?Ihave a couple .15 size MACS pipes. If one of the headers I've got fit the engine Imay add a pipe. When Ibuilt the plane Iinstalled plywood on the appropriate spot to hold the pipe mount, so it'd be an easy addition.
