RE: AEROFLY 5.7 AND JR 10X
Ron, please post a photo of the cable connections from your JR radio to the PC. You should not be in trainer mode and disable it. If you're using dual rates, you should calibrate your radio with the dual rate switch position at high rate. All program mixes should be disabled during calibration.
