RE: rearmounted carbs.
you might have to fabricate a motor box . or use standoffs . it could envolve making the nose longer. if the carb is too far inside the fuse of the plane , tunning is too much of a problem . you want the needles , just at the back of the cowl. and in front of the firewall. if its a corsair with
a long nose , you might not have a problem
