Hello
This happened to me when I got my E-Firestorm Flux Waterproof. The issue for me was that the car was delivered with it preprogrammed to run on Lipos and I am using NiMH batteries. The usermanual has the directions on how to use the transmitter to reprogram the car if you are using any other battery than Lipos. When it is set to Lipos, the low voltage Kick off kicks in and interferes. Your batteries may be fine, if you are not using lipos. Just reprogram the car using the manual. Worked for me!
ORIGINAL: XxINLINExX
First time posting on these forums <n00b></n00b>
Finally received my E-Firestorm yesterday ::woohoo:
Charged the battery over night (6 hours per manual). Brought it to work today since we have a huge parking lot to have some fun with it. But seem to be getting interference [&:] on a stand the truck accl/rev fine but when it's on the ground she travel's a couple feet then stops....regains signal travel another couple feet then stops....aaargh!
