Using an iPad let me try the vid. But you are right about the orange, the blinking of red/green is only while initializing. Also there aren't any other FASST's around. I'm gonna try the holding of the set button with my Tx off and hope she stays red.
Another problem while my servos are twitching out, my ESC will beep initially......then start beeping again while I try and fix the RX. So it's basically switching modes within the ESC as I try moving the awash with stick inputs while in HS mode. ??? Why would only the Aileron servo work proper and Elevator not at all? Sorry Tim I'm bombarding you with all these questions, i do appreciate it.
