Quickie Airfoil Templates
These are the PDF files for some of the Quickie wings that I was cutting. Since I published the Smasher plans and they do not have an airfoil on them, an airfoil may be needed by some people who don't have airfoil software. Ironically I'm one right now as my CompuFoil is acting up. I hate copy protection that doesn't work. But I did have all of these PDF files from when I was making templates, so I'm sharing them now. You can print these out on legal paper and cut them out on your fuselage sides. So putting a Viper wing on a wood fuselage is no big deal.
The three wings are the 66-012, the MH17, and the S8064 which is the section used on the Viper. The 66-012 is 9.875", The MH17 is 10". The S8064 is 9.875".
The 66-012 at 9.875" would not actually be thick enough for the 1.188" AMA rule. So the sheeting is thinned just a bit from 1/16". When it is sheeted with 1/16" it will be thick enough.
There are templates with both 3/16: and 1/4" leading edges is some cases.
Since I can't attach PDF's here, you will have to go to [link=http://www.rcpro.org/net/ThreadView.aspx?threadid=1013]Quickie Airfoil Templates[/link] to get them.
