Thread: ESM FW D-9
Old 01-24-2012, 02:50 PM
  #1354
n8622t
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ESM FW D-9
Not a thing wrong with that P47 I am going with a similar set up since yours looks so good. DA50 and a slimline. How is the firewall since you cut out the bottom section? You gonna need to reinforce in any way? What about the open fuse section...idea...take some thin balsa and wet one side so it will curve along the grain for you, then lay it in the opening from the firewall to the front of the fuse. Work it in and glue it. Piece the ends in then come back and trim it off...thin epoxy and paint it. It will help channel the heat away from the muffler and engine and keep hot air out of the fuse. Hope this helps since you already worked out how my engine is going on
n8622t is offline
