RE: using 3c lipo to run prop starter motor
Good point on checking the voltage at the balance point. Both batteries showed a zero voltage cell when measure to negative. However, one battery picked up the third cell when put back on the charger and one did not. The one battery held steady and took a good charge. I'm going to dissect the bad one and inspect. Thanks for the ideas!!
