ORIGINAL: Lunchboxer
Yeah, scale FTW for sure!!
It is interesting that they are not putting the 750-sized motor in it like the old Bruiser.. I mean, if you want power, you can always put BL setup in it, but just wondering why they didn't go w/ the 750 motor to separate it from the ''regular'' line-up of RCs.. !
In reading up on the history of the Bruiser, the 750 was used because back when the Bruiser was new, a stock Tamiya 540 motor wasn't strong enough to get the job done with the 6V the big custom 4000mah battery pack supplied so the 750 was sourced.
Now that tech in brushes, magnets, batteries, etc has improved a stock Tamiya 540 built these days can outperform the 750 used way back then. And we can use 7.2 volt high capacity packs or 7.4v lipos as well.
