RE: Regarding SP series engines, props and airspeed...
The hub from Ramoser is built for a 12mm shaft. The shaft of the 90SP has 7.86mm, so thats the value you should mail him. So what you get is a sleeve with an inner diameter of 7.86 mm and an outer diameter of 12mm.
regards
Andi
