Will airtronics servos work with Hitec plug RX
Currently Hitecs (S) plug, Airtonics (Z) plug which is the blue one and JR's plug are all interchangeable with no Modification and the same polarity. Completely interchangeable. Futaba is also 'if' the tab on there servo plug is removed.
So if your Airtronics servos have the blue 'Z' plug then yes they will plug right into the hitec Rx and work well. If your servos are the old style Airtronics with the black plug and three splines on it then no it will not. They can be made to work with some creative dremel work to remove the three splines but most importantly reverse the positive and negative leads on the plug which were opposite of everybody else.
John
