RE: 55 AX low needle setting
3-4 mm between the needle and the nozzle when the engine is at full throttle is a good place to start. As long as the low-speed needle starts out a a very rich setting, you'll be OK. Once the full-throttle setting is found, you can retard the throttle and set the low-speed mixture.
