RE: September Fury - a new Q-40 design
That doesnt look too bad, The cowl will require some creative mold making but it is doable and would definately be unique.
Your 12.5 inch area rule might not work in cowl area as I dont think it can be in the "cheek cowl" area but just behind where cowl meets fuse area should be fine. It would also probably be covered at the 5" deep area as well. (cockpit area) that area will probably be around 3" wide as it is a smooth taper from cowl to tip of tail. My AR6 is 4" wide in front and goes okay. I think that airplane will work as good as any with some work on air around the cowl. It is the wing and horsepower that are most important. If Lee doesnt want to do it I might after I finish my F5D project. I am going to do some kind of Q40 just dont know what yet..... Press on!
DE
