RE: .........
Hi Petey, Glad to hear that. Just make sure that you Lock-tight EVERYTHING! they come put together but you will have to unscrew all the frame screws and lock-tight them. Once you get it all set up you will find it VERY stable in the air. I've flown mine in 14 mph winds with no problems.
Also...if you haven't got one on your Belt cp that you can swap over, get yourself an Align tail rotor as soon as you can. They are the best for the job. The EXI tail rotors are cheap and break after a while.
