RE: avalanche trx needles
thanks dlrct actually got it back up and going to day .the 3 and 3 that the red cat rep said was a bit off the avalanche was a real pain to get started almost felt like my arm was going to fall off from pulling so much .os i went with what you had said 3/4 on the low and it finally started up got the high almost right where it needs to be .seceond time around it took a min to start but much eaiser than the first .turned in the low some more .even better on the third .still need to get the lsn down some because it is hesitant on the take off for two split seceonds but i will say that thing is a beast . right now wot for about 3 full sec its probally hitting 50 or 50 easy altho i dont do that very much cause i know its not good for the motor .now to just get the lsn tuned in just rigt for the take off and iam set .red cat said their safe to run at around 235 to 240 being the safe zone on their big blocks what would your in put be on the temps to be safe
