ORIGINAL: Velco
After talking a bit to Mirce I figured out that 50% more static from flying weight is really not necessary so I have come up with one more interesting solution for Rim 65cc on 12S (or any other motor with kV around 170 like AXI 5345/18) which is also more scale especially on Dora and it is Biela 3 blade 20x14. Would really look nice painted in black.
This is also quite interesting as well. Does ecalc show you what the current draw is on the 3 bladed prop at 100% throttle verses a 2 bladed prop? Obviously there will be more current draw for more load, which may require a larger battery pack(mah).
