RE: Servo Horn Adapters
Well, you might be able to make the wheel work. It's a bit hard to tell from the pics but the offset (center of wheel to center of hole used) looks close to the same. If it's pretty close then try the wheel. If not then, yeah, as proanti said, pick up a set of airtronics horns.
