RE: Rhino problems!! WHERE ARE YOU ERIC!!!
Just a head up, if you are using a UAT tank, this can be an issue as well. I have seen larger turbines pull so hard on the fuel system that small air bubbles form in the tank, and eventually into the turbine. Make sure when the turbine is at full power the sides of the UAT do not pull in. Hopefully you find out what the issue is.
