HI everyone,It was mentioned in the manual to use the supplied screws to mount the servos.
I have noticed that these screws are of a bigger diameter then the standard servo screws.
As a result they do not fit the brass washer supplied with the servo.
How are you supposed to screw these in?
Do I just force them in, and make them fit?
If I use the standard screws supplied with the servos they seem to small to bite into the pre drilled plywood supplied.
Any ideas?
Your help is much appreciated.
