RE: Old Lipos, hardly used, should I use them?
Quick test as stated, hook up a meter and run up the plane wide open for 15 seconds. See if the voltage plummets. If it seems to hold voltage, you could still have some good packs.
That's a pretty good load test for a quick check.
