RE: The Usual Cooling Issue
ps. Wanted to throw this out there... to cover up the inlet/outlet holes you can use wire window screen glued to the inside and painted to match. Optically it'll make the cutouts disappear, but still be transparant to air flow just like window screens in your house when the windows are opened. My Century Airwolf fuselage has air holes in it all covered with screen and painted to match the fuselage, I presume it should work well for airplane cowlings as well. Check your local hardware store for screen. It helps to maintain the scale look we're all after here! [>:]
- Michael
